MPC5744P spi slave mode
lyk
I have a question on spi slave mode:
        If I use SPI0 in slave mode, and set the PC4 as chip select pin, how to config PC4.
PetrS
it is enough to set respective MSCR[IBE] bit, e.g.
SIUL2.MSCR[36].B.IBE = 1;    // C[4]: Enable pad for input - SPI_0 CS0
BR, Petr
