Dear all,
I refer to the "Figure 18-2. Clock Tree - Part 1" of Reference Manual.
MMDC_CH1_CLK_ROOT is listed, but I was not able to find the module which used this clock with a reference manual.
Is this clock used in i.MX6Solo?
If this is not used, can I leave the related register the default?
Yuuki
Solved! Go to Solution.
MMDC_CH1_CLK_ROOT in i.MX6Solo is not used: Memory second channel is not
supported for the iMX6S, therefore related regs should not be touched.
Yuri
Yuri
