Is there any documentation for the USB stack used in the examples of the SDK? Are the examples + UM all we get? Are there plans on providing API documentation for both full speed and high speed host?
Solved! Go to Solution.
Hi Alan,
You can find the corresponding USB documentation inside the SDK package on the following path:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Thank you!
Intended for the LPC546XX area but I can't seem to mark it as such.
Hi Alan,
Hope it helps!
Carlos Mendoza
