Dear NXP engineer:
Now,I receive a S32R274RRUEVB board,But I'm not sure which simulator it uses.
Best is to use Lauterbach debugger.
If you like low cost solution you can use PEMicoro.
There is also a bunch of other vendors like: PLS, iSystem, GHS, erc.. but you have verify with them if the support this micro.
Peter
PS: you are talking about debugger. Not emulator/simulator.
