Current in Power-down mode
jirisvabik
I test example for LPC812 and LPC824 (LPCXpresso) periph_wkt. Current it cca 300uA in power-down mode. I tried to turn off the BOD power. No more significant result. What must be turned off? To reach the declared current (less than 1uA)? Thank you for your impulse. Jiri Svabik
soledad
Please check the below thread
LPC824 power down current too high
I hope this helps
Soledad
