i'm a beginner in MCUs world .
i'm facing some issues ...
in LPC17XX datasheet there is 6-output general purpose PWM available in LPC1768
I'm planning to use 7 PWM pin to control the speed of 7 BLDCs by ESCs
but i need one more PWM pin .(i need them separately)
sometimes it happen that some more pin of a kind are required separately(i mean asynchronous) do you have any idea how to solve this problem ?
by the way this micro has one specialized motor control PWM can i use it for 7th one ?
i may also need some more PWM pins for 2 or 3 DC motors (synchronous) .
I've found out that one expanding way is using multiplexers for synchronous buses .
one more way that i saw pple used with arduino was Latch method and shift register method ( in this method they use 74Hc595 )....
but they have their own difficulty ....
