imx6q porting issure
xulj
hi,
I have an issure when i was buildig image of linux kernel 3.10.17 by using yocto project, the reference doc is 《Freescale Yocto Project User's Guide》
when i run the command
$bitbake fsl-image-x11
it returns error as autotools.patch failed,more details pls see the attachment.thanks
Original Attachment has been moved to: log.do_patch.2756.zip
Labels (2)
Rita_Wang
Before you build your images, have you installed sucssesful the host packages for your Ubuntu host setup, in the 3.1 Host packages, you can see the detail command.
Rita
