S32K LIN package
S32K LIN package
cthhk
Dear Team:
We are evaluating S32K LIN software generated from S32DS SDK.
And when acting as Slave node, my board can talk to CANoe and works quite well.
Unfortunately when acting as Master node, error may occur in 2~3 minute after power-on. Please refer to attached snap shot for error message.
Could you give me some hint why this happens? Or anything I need to do with the SDK configuration?
And could you provide an example with test setup so that we can check our bench?
Appreciate your support!
Wang.
lukaszadrapa
I discussed it with SW team. The only known problem is erratum e10527:
Earlier versions of SDK used LPUART_CTRL[SBK] bit but this has been fixed in release BETA 0.9.0. Which version do you use? There are no known issues in this latest version.
Lukas
