Hello, we are using P2020RDB Evaluation board , we are unable to boot from any option(NOR, NAND and even SD also), , what could be the problem .so we connected to code warriour tap debugger and tried to access the nor flash. What could be the issue? Please help us to debug the eval board. console log message
Hello Naresh,
For flash programming, please refer to procedure described in https://community.nxp.com/docs/DOC-100896.
According to your log, it seems that the NOR flash is in protection state, please add and execte the Unprotection task before NOR flash programming.
Yiping
