is there a code example about analysising sine-cosine signal of kmz60?
xiangxu860
recently i use KMZ60 to get the rotor position of motor. there are two signals : sin(theta) and cos(theta).
i  use  look-up table method   to get the value of arctan().but i found the precision of rotor position i get is not sufficiently high.
so is there  a code example about analysising sine-cosine signal ?
thks!
xiangjun_rong
Hi, Xu,
Can you attach the user manual or data sheet of the KMZ60 here? I can not download it from public website of NXP.
After I get the doc, I will have a review.
BTW, do you know whether NXP provide library to track the rotor position?
Xiangjun Rong
xiangxu860
I'm so sorry to reply you now .
the attachments below are documents about KMZ60.
i don't know if NXP provide library to track the rotor position,could you please help me contact with the global NXP engineer which can deal with this problem?
thanks very much!
