armlmd vendor daemon
markngo
Our license server crashed along with armlmd vendor daemon (screenshot snippet from license.dat).
Does anyone have armlmd daemon that works for CodeWarrior IDE version 5.6.0.1462 for CodeWarrior Development Studio, ARM ISA Edition for Board Bring Up v2.1, Build 37 (see screenshot)?  We downloaded an armlmd daemon from arm.com but it does not work.
TomasPaez
Seems the version you are using has been purged from NXP system or is too old to know.
I do not see any legacy vendor supported by NXP called armlmd
However NXP does have the access this legacy version ARM 2.1 but works with mtwkrs daemon, so there must be a mistake on how the license is build and maybe it uses mtwrks instead of armlmd , if you want to try this please create a case.
Temp license for this product has been attached, try in a local machine using this certificate, make sure you have Metrowerks daemons within your vendor list.
hope this helps.
