I have NAND Flash which will have my application code and Images (Will be stored as bin files) for LCD display.I want to store application and images separately .Application will have location of all the images so that I can read these images and use it run time.
Nand flash size: 256 MB
Application size : 1MB approximately
Images size: 200 MB
Sdram size: 32 MB
I will be using ITRON OS .Please tell me is this possible. How to store these images separately in Nand flash .Is there any tool for it . Thanks in Advance.
Hi Arif
one can look at attached sdk gpmi example with description
in Chapter 13 Configuring the GPMI Controller pdf document
or look at ucl2.xml script of mfg tools utility.
i.MX 6 Series Software and Development Tool|NXP
