How to configure and use Flash as E2PROM to store Configuration settings
kalpeshbalar
How to configure Flash memory to use as a E2PROM to store my configuration settings?
Also, how can I access this configured portion of Flash to read and write my configuration settings?
For example:
Flash Partition 1: Size = 30KB
Flash Partition 2: Size = 2KB
Now How to access this 2KB partition to read and write?
I am using LPC11C14 and LPC open library in LPC expresso.
KBalar
Tags (2)
kerryzhou
Hi Kalpeshbalar,
  About this question, we have an application note about it, please refer this application note and it's sample code:
http://www.nxp.com/documents/application_note/AN11008.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VEND...
  Please refer to it at first.
  If you still have question after reading the AN, please let me know!
Wish it helps you!
Jingjing
