GPU 3d performance on IMX6 Dual SD platform
ifzhao
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Android Ver. 4.3
Linux Kernel 3.0.35
The performance on 3d test is not good. The FPS has dropped down to 7 or even less.
I try adjusting the fbmem size, but it didn't work.Could any one give any advice on this?
mike_susen
Hi If Zhao,
what 3d performance test you did run on board? I think that the best advice is upgrade to newest Android release.
Michal
ifzhao
We use AnTuTu App to do the 3d graphic testing. The performance is terrible.
Now that it's nearly on the MP stage , we can't take the risk to update the system.
Could you point out something we can do right now on 4.3?
mike_susen
Yes, i understand but most of bugs in gpu were fixed in the newest releases of Android. Please try it. On Android 4.3 i don't have any other suggestions.
Michal
