when I run ipu test, input is 1920x1080 raw YUYV 16bit stream, output is 1280x720 RGB888.
(i.mx6solo, linux 3.10.45)
I see lots of:
imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_10 = 0x00080000
and the screen is flickering. Reboot the machine, then run the same app, everything is ok. What's the problem?
