Content originally posted in LPCWare by lpcxpresso-support on Wed Jun 24 13:29:54 MST 2015
Which Wizard are you using, what options are being selected and at which point do you get the Stack overflow message? i.e. can you tell us exactly what you did, so we can try to reproduce here.
Note that Arch Linux is not a supported platform, but I would not expect that to be the cause of the problem.
