Content originally posted in LPCWare by karuna on Wed Feb 23 08:18:03 MST 2011
I am using LPCXpresso board and want to run a FTP client for transferring files in MMC/SD card to PC through Ethernet. For FTP , it needs two ports to be connected to FTP server..
Am using TCP/IP stack which comes with webserver example. Is it possible to open two ports at a time.. I tried but its not working.
Is there any sample program or tutorial for FTP client for microcontrollers which can work without OS?
or any alternative protocols?
Thanks in advance
