Content originally posted in LPCWare by riscy00 on Mon May 09 07:31:26 MST 2016HiI start to notice that the LPCexpresso complier build twice rather than once as previously done.I not sure why this happen. This is not related to LPC library and then application code in turns. It complies twice on application code.See attached logAppericate how to fix this, it slow down complier activity works.R. Original Attachment has been moved to: BuildTwiceIssue.txt.zip
