Content originally posted in LPCWare by caprock on Fri Jan 13 09:08:07 MST 2012
Great looking demos!
I stand by my initial decision: SPI for ease of connection in a prototype application.
And NO, I have not settled on a target QVGA display or code, and at the moment, my target design will probably not require anything elaborate; but all is possible.
Clearly a serial connection is not desirable on a real product, but consider that this is an upgrade to an OLED 96x64 display on the EA base board - big.
And unfortunately, with limited physical abilities, best to stick with fewer prototype connections; leave that for a new board layout.
Lastly, THANK YOU for your insights! I appreciate all comments and responses.
