LPC4357- Using SGPIO to get data at the rate of 27MHz
lpcware
Content originally posted in LPCWare by chidambaramnkl on Fri Apr 08 03:00:53 MST 2016
i am using sgpio to get video data from video decoder at the data rate of 27 MHz. Will SGPIO  work at this  data rate ?
lpcware
bump
lpcware
Content originally posted in LPCWare by chidambaramnkl on Wed Apr 20 00:18:09 MST 2016
thank you. It was working fine with GPIO at 27MHz Pixel clock rate. GPIO is doing great job in our project.We tried with SCT but it wasn't work.
lpcware
Content originally posted in LPCWare by bavarian on Mon Apr 11 03:58:46 MST 2016
The SGPIO block and pins will have no problem to run on 27MHz, you only need to create a suitable system frequency with the PLL which is x * 27MHz.
And of course it depends on the amount of data you want to clock in. It makes a big difference if you clock in a 27MBit signal or a 27MByte signal. Somehow you also need to process this amount of data or at least shuffle it from the SGPIO port to another interface like USB or ethernet.
There are 2 app notes which realize a camera interface with SGPIO, but on lower data rate:
https://www.lpcware.com/content/nxpfile/an11196-camera-interface-design-using-sgpio
https://www.lpcware.com/content/nxpfile/an11343-sgpio-camera-module-design-using-lpc4300
NXP Support Team.
