Content originally posted in LPCWare by chidambaramnkl on Mon May 23 01:17:18 MST 2016
While start debugging i have problem with lpclink 2 debugger tool. the Target board is LPC4357 processor. Error message given by the debugger is given below. Can any one Help me to get out of this problem
Error in final launch sequence
Failed to execute MI command:
-target-select extended-remote | crt_emu_cm_redlink -msg-port=52143 -g -mi -2 -pLPC4357 -vendor=NXP -ResetScript=LPC18LPC43InternalFLASHBootResetscript.scp -reset= -ProbeHandle=1 -CoreIndex=0 -cache=disable -flash-driver=LPC18x7_43x7_2x512_BootA.cfx
Error message from debugger back end:
Remote communication error. Target disconnected.: No error.
