LPC1788 NOT GETTING PROGRAMMED
lpcware
Content originally posted in LPCWare by MAHESH V S on Fri May 02 04:41:13 MST 2014
Hi All,
I've been working on LPC1788FBD208, quite a while on Display board product development.
it worked fine, after developing Firmware & loading.
but, after testing it for few days, later--when I tried to Re-program/ Re-Flash the Microcontroller,
it was not able to RE-PROGRAM/ RE-FLASH, with failing to detect the IC via JTAG / UART.
NEED YOU HELP TO RESOLVE THIS ISSUE.
Mahesh V S
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri May 02 05:45:22 MST 2014
Please read the FAQ:
http://www.lpcware.com/content/faq/lpcxpresso/regaining-debug-access
