GoodLink LED on LPC1787
lpcware
Content originally posted in LPCWare by SimonThome on Fri Oct 17 00:04:13 MST 2014
Is there a know issue with the "GoodLink" (USB_UP_LED2 P0[13) functionality on the LPC1787FBD208 (Revision E)?
On my device the LED is active when the host PC is connected, but when the USB cable is removed the LED does not turn off. There is no mention of this in the errata sheet.
