KW21Z pin-compatibility with KW20Z
zeshanyousaf
Hi ,
I still don't see KW21Z in the market. When it will be available or launched?
Is it pin-compatible with KW20z?
We want to evaluate KW21z. How it is possible? Should we use KW20z Freedom evaluation board (makes sense if pin-compatible with KW20z?)
Is datasheet available for KW21z?
Zeshan
mario_castaneda
Hi Zeshan
The KW21Z is not available, it will be launched this year.
You can check the next link for all the information about KW21Z,
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/kinetis-cortex-m-mcus/w-s...?
For more information, contact your local sales
Best Regards
Mario
