Clear FCCU_NCF_Sx Issue
liujinhang
Hi:
     why doesn't the FCCU_NCF_Sx can be cleared by the following code ?
  FCCU.NCFK.R = FCCU_NCFK_KEY;
  FCCU.CTRL.B.OPR = 0xC;
  while(FCCU.CTRL.B.OPS != 0x3);
davidtosenovjan
You can use following code that cleat all faults (you can modify it to clear only some faults):
void ClearNCF(void)
    uint32_t i;
    for(i=0;i<4;i++)
        FCCU.NCF_S[i].R = 0xFFFFFFFF;
        };              /* wait for the completion of the operation */
Please also pay attention to following documents:
http://cache.freescale.com/files/32bit/doc/eng_bulletin/EB758.pdf
MPC574xP - FCCU configuration guide
