BLE "Programmable transmit output power"
valentinberthom
On the datasheet, of the KW3xx KW4xx chips, its stated that  BLE has a "Programmable transmit output power from -18 dBm to +5 dBm with DC/DC bypass and buck modes of operation" I would like to know what precision I could get in term of transmit power configuration?
Thank you,
Valentin
antonioconcio
Hi Valentin,
Please refer to the file "BLEADG.pdf" at the following path: C:\Freescale\KW40Z_Connectivity_Software_1.0.1\ConnSw\doc
Hope this helps,
Antonio
sensenthuran
If we are using the hci_app.bin for kw40/41z, how we can change the tx  power dynamically with bluez antonioconcio
The default value is set:
/app/common/ble_controller_task_config.h
#ifndef mAdvertisingDefaultTxPower_c
#define mAdvertisingDefaultTxPower_c    0
#endif
