GDB server for MPC5774
sharatswamy
Is there a particular GDB server which can be used along with S32 eclipse IDE for debugging MPC 5774 power architecture micro controller. What other debugging environment options available?
martin_kovar
S32DS for Power Architecture contains it's own GDB server. This server can be used stand-alone or as the part of S32DS.
About debugging environments, you can use GreenHills solution or Lauterbach Development Tools. Both solutions are licensed.
Martin
sharatswamy
Hello Martin,
Thank you very much for the response.
Sharat
Embitel India
