Hi Every one,
we run below command on target board.we have the issue .That issue mentioned in the below.
insmod /lib/modules/3.14.28-1.0.0_ga+g91cf351/kernel/drivers/net/wireless/bcmdhd/bcmdhd.ko firmware_path=/lib/firmware/bcm/fw_bcmdhd.bin nvram_path=/lib/firmware/bcm/nvram.txt iface_name=wlan
any error message?
Hi ,
Thanks for your reply.we solved that issue.
