How to update new firmware of OTA server in Beekit project?
seanwu
Dear sir,
     I build a new project "Ha Combined Interface" for KW21 from Beekit.
And let it be an OTA Cluster Server.
As we know OTA server can send new image to OTA client, and after OTA client getting the new image, it will reset to bootloader mode to update new image.
But if I want to update the new firmware of OTA server, may I modify the settings from Beekit or how I do?
Thanks.
BR,
Sean Wu
Weikeng Inc.
Tags (2)
seanwu
Dear sir,
About "gUpgradeImageOnCurrentDevice_d", I couldn't understand what it mean. Could you please describe it?
About the alternative method you suggested, I can't use test tool "OTA updates" to update server, right?
If I build my PC application with UART interface to update server,
do I need modify the code of server beside enabling gUpgradeImageOnCurrentDevice_d?
Finally, how I to build my PC application? Do you teach me and what document and sample code could be studied?
Thanks.
BR,
Sean
