lcd 显示问题
lcd 显示问题
kevin_xk
大家好 我现在使用的是 飞思卡尔imx53 在做液晶显示的时候 在屏幕的右侧缺少一个像素,希望有人可以指点一下
joanxie
what output resolution do you use? could you share your detailed operation?
kevin_xk
resolution : 800*480
lcd_xsize = 800;
lcd_ysize = 480;
left_margin = 39;
right_margin = 40;
upper_margin = 19;
lower_margin = 16;
hsync_len = 7;
vsync_len = 4;
joanxie
mx53 can support 800x480 output, did you use the new lcd ? and pls check if your hardware connection is ok.
