Issue for gstreamer1.0-plugins-bad
veeranjaneyulug
Hi every one,
Have a great day.
We run gstreamer1.0-plugins-bad with bitbake. This gave some plugins only We need libsrtp. So and libgstsrtp. So     file. Where these libraries created?. And how to and gstreamer1.0 srtp plugins in local. Conf. Gave me and idea. Asap
Thans & regards
Veeranjaneyulu
gusarambula
Hello Veeranjaneyulu G,
Have you looked at the gstreamer1.0-plugins-good package? Most of the RTP plugins are contained there. You may find more details on how the plugins are classified on each package on the following document from Freedesktop:
http://gstreamer.freedesktop.org/documentation/plugins.html
As for how to add the packages to the local.conf file, you may do so using INSTALL_IMAGE_append as follows:
IMAGE_INSTALL_append = “ gstreamer1.0-plugins-good”
I hope this helps!
