p2041rdb SATA
p2041rdb SATA
连营张
I received our P2041RDB sometimes ago but could never have SATA working. I did according to the SATA section of"target.ref" document,but could't  see the disk device using the devs command,Is there anything that needs to be modified to have the SATA disk working ?In addition, I'm sure rcw supports sata.Thank you in advance.1.pngQQ图片20151021160111.png
