It seems that I can't use floating point in a linux application.
I checked the default configuration in the jernel build (from buildroot), and I see that PPC_FPU is selected.
Do I need to add sw emulation to kernel build ? What is missing for floating point support ?
Thank you,
Ran
Check compilation option and compilation library for your application.
Freescale offers CodeWarrior compiler for the MPC83xx (http://www.freescale.com/tools/embedded-software-and-tools/software-development-tools/codewarrior-de...).
This compiler supports hardware and software floating point.
There is Linux GNU compiler for the MPC834x.
Pavel
