hi,
Thank you for contacting us.
- is this problem in a specific project or a common issue for all project? how it work if you create a new project with wizard?
- remove .metadata folder in your current workspace then restart CW to test it again.
- do you use Freescale demo board? If yes, which one?
- please follow this link to check your connection problem:
Debugging Failure: Check List and Hints | MCU on Eclipse
Zhang Jun
