imx6 solo when input vedio color space is YUV422
jony_oy
the enviroment is that .we use imx6 solo processor,the input signal is HDMI,whe the input vedio color space is YUV422,the picture output is green,
the sii9135 convert vedio into YUV420 8bit, how can i solve the problem,thanks!
Labels (3)
Tags (2)
joanxie
what's your input mode you use? BT1120 mode ? and did you check the hardware connection?
what do  you mean "the sii9135 convert vedio into YUV420 8bit"?
