How can I build a sample project for FRDM-K64F to test CyaSSL in KDS Linux 64-bit
jingsong
I am looking to build a sample project in KDS v3.0 running on Ubuntu 64-bit Linux.  I have installed KSDK 1.2 and MQX/CyaSSL patch.  Can someone offer guidelines for doing this?
Carlos_Mendoza
Hi Jingsong Fu,
I think that the following post created by our colleague Lobdell Maclain might be helpful for you, it explains how to build and run the MQX HTTPS Server example with CyaSSLs:
How To: Build and run the MQX HTTPS Server example with CyaSSL
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Carlos_Mendoza
Hi Jingsong Fu,
Hope it helps!
Carlos Mendoza
