MPXV5050GC6U
MPXV5050GC6U
cindiheying
- Is this part able to be washed (using a lead free, water washable solder past)?
TomasVaverka
Hi Cindi,
Any cleaner that  enters the sensor pressure opening may have adverse effects on the device. So, sealing the access hole on the part with kapton tape is absolutely recommended. You can also plug the part with a cap before cleaning.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
cindiheying
Thanks. That is exactly what i thought but wanted to verify.
TomasVaverka
Hi Cindi,
Tomas
