TWR-K21F120M float Data types
黃佑煊
Dear sir, I have a TWR-K21F120M
But, when I want to use floating-point operations, there will be an error
Thank you very much ~~
ivadorazinova
Hello 佑煊 黃,
Please, check settings in KDS.
these documents could help you solve your problem:
Printing Floating point values to fsl_debug_console FRDM-K64F
and printf() with float values
I hope it helps,
Iva
黃佑煊
Dear sir,
Sorry! I do not understand how to set this.
ivadorazinova
Dear 佑煊 黃,
Never mind. Please, try do it by this way:
Change std_prv.h to following:
#ifndef STD_FP_IO//DES added #ifndef
#define STD_FP_IO 0
#endif
and change the value in Preprocessor STD_FP_IO = 1
Iva
黃佑煊
Dear sir,
I can not find the preprocessor options
Hi 佑煊,
Do you use CW10.6 ?
In you screenshot , where show the float error ?
And about the float configuration on CodeWarrior, you can select on here :
And i have test on my side (mk21fn1m0 - CW10.6), when define like your code (float tt; tt = 2.0f),  it can work well.
So could you show detail the float error .
Alice
If this post answers your question, please click the Correct Answer button.
If this post help your question, please click the helpful Answer button.
