iMX6 HAB Problem
iMX6 HAB Problem
aureliencourrie
I'm currently trying tu use HAB on a board specific using iMX6DL with u-boot 2014.04 ( from freescale.)
I've the following line in my board cfg file
IMAGE_VERSION 2
BOOT_FROM   sd
CSF 0x2000
When I compile u-boot i've the following output
Image Type:   Freescale IMX Boot Image
Image Ver:    2 (i.MX53/6 compatible)
Mode:         DCD
Data Size:    290816 Bytes = 284.00 kB = 0.28 MB
Load Address: 177ff420
Entry Point:  17800000
HAB Blocks:   177ff400 00000000 00044c00
I've created the key using CST tools 2.2 (with my own serial and pass_key.txt files)
cd keys
./hab4_pki_tree.sh (n,2048,10,n)
cd ../crts
../linux/srktool -h 4 -t SRK_1_2_3_4_table.bin -e SRK_1_2_3_4_fuse.bin -d sha256 -c ./SRK1_sha256_2048_65537_v3_usr_crt.pem,./SRK2_sha256_2048_65537_v3_usr_crt.pem,./SRK3_sha256_2048_65537_v3_usr_crt.pem,./SRK4_sha256_2048_65537_v3_usr_crt.pem -f 1
My u-boot.csf is :
[Header]
  Version = 4.0
   Security Configuration = Open
   Hash Algorithm = sha256
   Engine Configuration = 0
   Certificate Format = X509
   Signature Format = CMS
[Install SRK]
   File = "./crts/SRK_1_2_3_4_table.bin"
   Source index = 0
[Install CSFK]
   File = "./crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
   Verification index = 0
   Target index = 2
   File = "./crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem"
# Sign padded u-boot starting at the IVT through to the end with
# lenght 0x2F000 (padded u-boot lenght) - 0x400 (IVT offset) = 0x2EC00
# This covers the essential parts: IVT, boot data and DCD.
# Blocks have the following definition:
#  Image block start address on i.MX, Offset from start of image file,
#  Length of block in bytes, image data file
[Authenticate Data]
   Verification index = 2
   Blocks = 0x177ff400 0x000 0x44c00 ".u-boot-pad.bin"
I generate the u-boot-signed file using following commands
./linux/cst --o u-boot_csf.bin < u-boot.csf
cat u-boot-pad.bin u-boot_csf.bin > u-boot-signed.bin
I burn the SRK fuse on the iMX
and copy my u-boot signed on the eMMC
Everything is fine (no error) and when I boot up the hab_status give me the following output
Secure boot disabled
HAB Configuration: 0xf0, HAB State: 0x66
--------- HAB Event 1 -----------------
event data:
        0xdb 0x00 0x14 0x41 0x33 0x0c 0xa0 0x00
        0x00 0x00 0x00 0x00 0x17 0x7f 0xf4 0x00
        0x00 0x00 0x00 0x20
--------- HAB Event 2 -----------------
event data:
        0x00 0x00 0x00 0x00 0x17 0x7f 0xf4 0x2c
        0x00 0x00 0x03 0x08
--------- HAB Event 3 -----------------
event data:
        0x00 0x00 0x00 0x00 0x17 0x7f 0xf4 0x20
        0x00 0x00 0x00 0x01
--------- HAB Event 4 -----------------
event data:
        0x00 0x00 0x00 0x00 0x17 0x80 0x00 0x00
        0x00 0x00 0x00 0x04
--------- HAB Event 5 -----------------
event data:
        0xdb 0x00 0x14 0x41 0x33 0x1d 0xc0 0x00
        0xbe 0x00 0x0c 0x00 0x03 0x17 0x00 0x00
        0x00 0x00 0x00 0x48
Any ideas ??
Thanks in advance
raulcardenas-b4
Hi Wee Do,
Looking at the log, it seems that the problem is an invalid key. And looking at your procedure, I believe the problem is here:
cd keys
cd ../crts
By answering 'n' to the last question, the PKI tree is build for "fast authentication". Your CSF file is for normal authentication.
And example of fast authentication is:
[Header]
Version = 4.1
Engine = ANY
[Install SRK]
File = “../crts/TBL_1_sha256+tbl.bin”
Source index = 0
[Install NOCAK]
File = “../crts/SRK1_sha256_2048_65537_v3_usr_crt.pem”
[Authenticate CSF]
#whole line comment
[Authenticate Data] # part line comment
Blocks = 0x877fb000 0x000 0x48000 “signed-u-boot.bin"
By the way here is parsing of your log:
Persistent  | T  |  L   | P  | Contents
Memory      | a  |  e   | a  |
Record      | g  |  n   | r  |
Type        |    |  g   |    |
            |    |  t   |    |
            |    |  h   |    |
Event       |0xdb|0x0014|0x41| SRCE Field: 33 0c a0 00
            |    |      |    |             STS = HAB_FAILURE (0x33)
            |    |      |    |             RSN = HAB_INV_ASSERTION (0x0C)
            |    |      |    |             CTX = HAB_CTX_ASSERT (0xA0)
            |    |      |    |             ENG = HAB_ENG_ANY (0x00)
            |    |      |    | Evt Data (hex):
            |    |      |    |  00 00 00 00 17 7f f4 00 00 00 00 20
            |    |      |    |  00 00 00 00 17 7f f4 2c 00 00 03 08
            |    |      |    |  00 00 00 00 17 7f f4 20 00 00 00 01
            |    |      |    |  00 00 00 00 17 80 00 00 00 00 00 04
Event       |0xdb|0x0014|0x41| SRCE Field: 33 1d c0 00
            |    |      |    |             RSN = HAB_INV_KEY (0x1D)
            |    |      |    |             CTX = HAB_CTX_COMMAND (0xC0)
            |    |      |    | Cmd Field:  0xbe000c00
            |    |      |    |             CMD: HAB_CMD_INS_KEY (0xbe)
            |    |      |    |             LEN: 0x000c
            |    |      |    |             FLG: 0x03
            |    |      |    |                  FLAGS: NOTHING YET
            |    |      |    | PAST Field: 0x03170000
            |    |      |    | Crt. addr:  0x00000048
Raul Cardenas
raulcardenas-b4
Hi Wee Do,
cd keys
cd ../crts
[Header]
Version = 4.1
Engine = ANY
[Install SRK]
Source index = 0
[Install NOCAK]
[Authenticate CSF]
#whole line comment
Type        |    |  g   |    |
            |    |  t   |    |
            |    |  h   |    |
            |    |      |    |             LEN: 0x000c
            |    |      |    |             FLG: 0x03
Raul Cardenas
aureliencourrie
Answering 'y' to the last question and it's work now !!!
Thank you.You've made my day.
I owe you one ;-) !!
