The information is not provided in the current documentation.
See below info about these details:
We checked the linker for the information you asked and it goes like this:
Pascal
Freescale Technical Support
Pascal
Thank Pascal.
While i still not clearly.
I know that , for example fun(3)(0) , it is meaning the leaf function , that is the last function of one branch.
While fun(3)(2) , the 2 meaning what ? (in my project , it is Init(3)(2)) .
Thank !
Better is to use an example.
In this case I've create a project with the wizard.
After to have enabled the "-M -StackConsumption" options the map file is generated.
Test_1: without local variable
main.c file:
void main(void) {
/* put your own code here */
// int val_1=0;
// char val_2=0;
EnableInterrupts;
for(;;) {
_FEED_COP(); /* feeds the dog */
} /* loop forever */
/* please make sure that you never leave main */
Map file
main and _Startup Group
+- main
+- _Startup
+- Init(3)(3)
+- main(3)(0) (see above)
Test_2: with val_1 local variable
main.c file:
void main(void) {
int val_1=0;
// char val_2=0;
Map file
+- main
+- _Startup
+- Init(3)(3)
+- main(3)(2) (see above)
Test_3: with val_1 & val_2 local variables
main.c file:
void main(void) {
int val_1=0;
char val_2=0;
Map file
+- main
+- _Startup
+- Init(3)(3)
+- main(3)(3)
The second information gives the Stack Consumption which are local variables and other local definition using stack for the function.
Pascal
Sorry that I cannot address any document to describe the details for Dependency Tree. From your screenshot, it seems that the function Init() calls two subroutines, and these subroutines may be in assembly code or in libraries.
