What is the minimum instruction cycle time for the MK20DX256?
garyk_
I'm creating a programmable pulse generator that needs high resolution on the output delay & pulse widths.
Carlos_Musich
Hi Gary,
Kinetis devices are based on ARM cores, K Series use Cortex M4. You can find the information you need in ARM Infocenter.
Carlos
