I am trying to program a Kinetics EA uC using Code Warrior but I do not see EA listed as one of the uC options. When I installed CW I installled ALL the options so it should be here somewere, any help would be very much apprechated.
Kas
Hi Kas,
Are you using MCU V10.6?
Do you mean these KEA devices?
Have you installed the updates (menu Help > Install New Software) from
http://freescale.com/lgfiles/updates/Eclipse/MCU10_6/com.freescale.mcu.updatesite
Erich
Hello Erich,
I am using 10.5 as that is what came with the TRK-KEA kit, I have updated the software with no luck. I am now downloading 10.6 and will see how that works.
Kas
