Problem in running LTIB..
jagadeeshv
Hi all,
I'm new one to LTIB...
i've followed instructions from some forums and sites to DL & run LTIB..
i've stopped at "wget-ssl" & "rpm build"
Processing platform: Host support packages
using /home/jag/Desktop/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: autoconf
Processing: libtool
Processing: lkc
Processing: patch
Processing: wget-ssl
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/ltib/usr/src/rpm' --define '_prefix /opt/ltib/usr' --define '_tmppath /home/jag/Desktop/ltib/tmp' --define '_rpmdir /opt/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/ltib/usr/share/man' --define '_sysconfdir /opt/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/jag/Desktop/ltib/dist/lfs-5.1/wget/wget-ssl.spec
checking for libgnutls... no
configure: error: --with-ssl was given, but GNUTLS is not available.
error: Bad exit status from /home/jag/Desktop/ltib/tmp/rpm-tmp.13495 (%build)
RPM build errors:
Build time for wget-ssl: 48 seconds
Failed building wget-ssl
Died at ./ltib line 1492.
traceback:
main::build_host_rpms:1492
  main::host_checks:1554
   main:562
Started: Sun Sep 14 02:07:47 2014
Ended:   Sun Sep 14 02:08:35 2014
Elapsed: 48 seconds
VERSION          : 13.2.1
CVS_VERSION      : $Revision: 1.93 $ (Savannah)
PLATFORM         : host
GNUTARCH         : i686
TOOLCHAIN        :
TOOLCHAIN_CFLAGS :
These packages failed to build:
wget-ssl
Build Failed
I've tried all fixes got from net...
but i'm unable to run LTIB on my PC...
I've installed Ubuntu 10.04 in my VMplayer..
please suggest me solution..
thanQ in advance...!!!!!!
jagadeeshv
Hi All,
after all I've compiled and run LTIB on my PC..
but this time i got another source from friend, which is 1.3GB tar file,
now i got all required libraries and sources are with in the tar file,
"L3.0.35_4.1.0_130816_source.tar".....
Now no issues in running and using LTIB...
thankyou all.....
fabio_estevam
I would recommend you to use Yocto instead. You will probably be up and running quicker.
Rita_Wang
Hi jagadeesh,
Which board and BSP are you using?
(Dan)
jagadeeshv
HI Dan,
for Just now my task is to run LTIB successfully on my PC....
after that i'll use it for iMX6sl...
now is that matter of "BSP"....???
Rita_Wang
Hi jagadeesh,
No, I mean which version  BSP you are using so that I can give you the user guide document. As you have installed the LTIB on your PC, and the next step is to build the BSP using LTIB.
Dan
jagadeeshv
Hi Dan,
did you got the  correct answer for the BSP version.... ??
i need some help... urgent..
I've installed LTIB .. following these instructions from the below link....
LTIB : Download
and installed the required packages...
thanks in advance...!!
jagadeeshv
hi Dan,
my ubuntu configuration ....
jag@ubuntu:~$ uname -a
Linux ubuntu 2.6.32-66-generic #132-Ubuntu SMP Mon Sep 1 18:36:19 UTC 2014 i686 GNU/Linux
jag@ubuntu:~$
LuisCasado
jagadeeshv
Hi Luis Casado...
I've followed the above two links...
and installed all patches suggested by them...
after running LTIB a got this log....
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: libtool
Processing: lkc
Processing: patch
Use of uninitialized value in string eq at /home/jag/Desktop/ltib/bin/Ltibutils.pm line 370.
Try wget-1.14-perl5.18-fix.patch.md5 from the GPP
http://bitshrine.org/gpp//wget-1.14-perl5.18-fix.patch.md5:
2014-09-15 08:59:36 ERROR 404: Not Found.
Try wget-1.14-perl5.18-fix.patch from the GPP
http://bitshrine.org/gpp//wget-1.14-perl5.18-fix.patch:
2014-09-15 08:59:37 ERROR 404: Not Found.
Can't get: wget-1.14-perl5.18-fix.patch at ./ltib line 790.
Died at ./ltib line 1380.
traceback:
main::build_host_rpms:1380
  main::host_checks:1435
   main:542
Started: Mon Sep 15 08:59:35 2014
Ended:   Mon Sep 15 08:59:37 2014
Elapsed: 2 seconds
wget-ssl
Build Failed
for wget-ssl building error... all are suggested that .." include --without-ssl " in ./config line in this path  dist/lfs-5.1/wget/wget.spec
but this is already exist... in that line..
I'm unable to run this....
thanQ.. n suggest me how to build correctly...
LuisCasado
Your build fails because some packages are not found in bitshrine.org
But I don't know why that patch should be needed, as LTIB builds wget-1.9.1.tar.gz that you should have in /opt/Freescale/pkgs
What is the BSP you're installing?
Luis
jagadeeshv
Hi Luis,
previously... I run some scripts from some other forum... so i got them..
now i've cleared all those things and run the LTIB again...
i got struced again in processing wget-ssl...
the log is here..
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: libtool
Processing: lkc
Processing: patch
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/ltib/usr/src/rpm/BUILD/wget-1.14
Remove this by hand if you really want to rebuild this package from scratch
traceback:
   main:562
Started: Sat Sep 27 10:35:30 2014
Ended:   Sat Sep 27 10:35:30 2014
Elapsed: 0 seconds
VERSION          : 13.2.1
PLATFORM         : host
GNUTARCH         : i686
TOOLCHAIN        :
TOOLCHAIN_CFLAGS :
wget-ssl
Build Failed
i'm new one to the LTIB and want run LTIB on my PC (UBUNTU 10.04)...
if I pass in that i'll get work for iMX6SL......
so please help me to set this....
got this log after removing wget.spec..
checking for compress in -lz... (cached) yes
checking for gpg_err_init in -lgpg-error... no
checking for gcry_control in -lgcrypt... no
error: Bad exit status from /home/jag/Desktop/ltib/tmp/rpm-tmp.87523 (%build)
RPM build errors:
Build time for wget-ssl: 37 seconds
traceback:
   main:562
Started: Sat Sep 27 10:46:20 2014
Ended:   Sat Sep 27 10:46:57 2014
Elapsed: 37 seconds
VERSION          : 13.2.1
PLATFORM         : host
GNUTARCH         : i686
TOOLCHAIN        :
TOOLCHAIN_CFLAGS :
wget-ssl
Build Failed
please help me to fix this....
thanks in advance..
