You experienced problem with the Jtag interface and your board.
To resume the situation, the connection is working with the demoboard but not with your board.
It seems there is a problem with the JTag onboard design.
Please have a look to the chapter 11 in the manual:
I checked with my colleague working to the Hardware team.
We suggest you to check the JTAG (on your board) interface with respect of EVM solution.
There is an issue with the 8013 chip.
Don't think this can help you.
Please have a look to the FAQ:
If you meet more info we suggest you to log it in our CRM system.
Please use Freescale on line support web page.
- Go to following URL:
http://www.freescale.com/TechSupport - Click on Submit a Service Request. You will come to a login page.
- You can submit your request through the web from there.
In the Service request, provide us the following info:
the Tool version used.
To do that you must:
* CW:
Start the IDE and click on Help | About Metrowerks CodeWarrior.
Click on Installed Products
Provide us all info displayed.
Or you can save them in a txt file.
In order to get some info could you please send us the log file of the communication?
To generate this file you must:
- open the CCS windows,
- type 'log verbose ads.log',
-type 'log quiet'.
Pascal
