Hi aLUNZ,
I recently ran into the same problem... p&e driver on a kernel which is too new. My kernel is 2.6.27.x and the linux wrappers interface fails to compile the driver wrapper.
Have you found a fix or did you just use an older kernel?
... or did you win the lottery yet? I have have been trying to win for years now...
Cheers,
Dave
No luck with the lottery so far (maybe I should actually buy a ticket - do you think that would help?).
Way back in Septembe P&E were kind enough to send to me (the then unreleased) updated drivers. We had mixed results with those drivers
Since then our development has progressed to the point where we did not actually need the p&e tools as much so we have not been paying attention to any later driver releases. We know that we will need to use the tools again in the not too distant future, but we have put off that particular headache until then.
One option that we are seriously considering is to maintain a VM development platform at a fixed kernel version just to be able to use the p&e device.
Good luck,
aLUNZ
