imx6 AI board mipi camera
xiaoxiongdeng
hi all
     recently, I imported a mipi camera to IMX6 AI board , refered to  ov5640_mipi.c
     now , when i  clicked the cam apk , IMX6 can receive the mipi data , but the picture is not correct when preview .
     who can help me !
     thanks a lot !
  attached is the picture when preview  .
Labels (2)
Tags (4)
Hi Xiaoxiong
you should modify mipi sources for your sensor, as it was performed at link below
Re: i.MX6 OV5647 Bayer sensor driver (ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0)
chip
xiaoxiongdeng
     chipexpert . Thanks for your help. My question had been resolved.
I had modify only 2 things . One is the IPU Channel :  using IPU1 CSI0 in IMX6Q . The other is that modify the previewsize setting in ioctl_enum_framesizes  before preview.
    The picture is error , because of the pixel size in kernel  is not match the HAL setting .
