Hi everyone regarding K Series Microcontrollers , Unable to drag the .wsd file into the project ..
sivakumarananth
I am unable to load the bsp (.wsd) file into my project. The procedure says to drag and drop the file in order to get the bsp loaded. I have done it for evaluation version but now after purchasing my license unable to load my bsp file into my project. Need to know the way to load it .. Dont know where I make the mistake ? Thanks in advance
ZhangJennie
do you use CodeWarrior or IAR? if Codewarrior, the project file is .project but not .wsd. please check this point.
