I'd like to see how it is going to be fast to develop a motor driver, however I couldn't solve the puzzle of finding even a single example!
My company interested in MK20 series. We are planning to replace our existing motor controller designs with Freescale.
Thanks.
Hi murat fidan,
Acutally, in our www.freescale.com, there still has a motor control libray based on cortex_m4, you can refer to it.
The link is : Embedded Software Motor Control Libraries
The librarie name is : CORTEX_M4_FSLESL
I wish it helps you!
Best regards!
Jing
Hi murat,
If you want use K20 50MHz series , you can download the sample code "KINETIS_50MHZ_SC" at below link:
There is a project using PWM , you can find it after you download it . E:\...\kinetis_50MHz_sc\k20d50m_sc_baremetal\build\iar\pwm_led
Maybe you will need pdb_adc_demo , it can be found at this folder: E:\...\kinetis_50MHz_sc\k20d50m_sc_baremetal\build\iar\pdb_adc_demo
