I am working with CodeWarrior 10.2 on a Windows 7 Professional PC.
Suddenly today I cannot no more open all my projects based on a Processor Expert file project (like my BSP projects I developed).
When I try to open a PE-based project I get the following error:
"Could not initialize class com.processorexpert.configuration.PEConfiguration" (see the attached screenshots).
How can I fix this issue?
Solved! Go to Solution.
1. please try to remove .metadata folder in your current workspace then reopen CW to test it again. 2. if step 1 can not help, please uninstall CW10.2 then reinstall it again. please make sure you have admin right during install. 3. CW10.4 is released, we highly recommend you use CW10.4 instead, here is the CW10.4 link: https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10&tid=CWH
