how to measure CPU cycle in full chip simulation mode for HCS08 device.
hotashu
hello,
I use codewarrior for mcu 6.3 before for hcs08 device, in full chip simulaton mode there is trace component to meature CPU cycle between to lines of code.
now i use eclipse 10.4 but can't find this feature, how to implement the same feature in eclipse for 8bit device?
thansk
Hotas
hotashu
still not figure it out. can anyone help me?
BlackNight
That Trace component does not exist in Eclipse. But you can use the menu PEMicro > Show Cycle Counter.
Not the same, but should give you the information you need.
I hope this helps.
